FX3 uvc only 15 FPS
bai
Hello.
First, my goal is a streamer application (uvc) which capable to stream YUV data.(According to an75779)
The sensor output is 1280*720 30fps YUY422,DVP 8 bit.
So my GPIF is 8 bits,LD_ADDR_COUNT/LD_DATA_COUNT is 16367.
Other configurations have not been changed because I think they are consistent with the sensor I am using, but the UVC output is only 15FPS at the moment.And the image is normal
Can you give me some advice?
AliAsgar
1. Could you let us know the details on the frame blanking?
2. Could you share the debug prints with us?
AliAsgar
AliAsgar
AliAsgar
bai
I solved the problem because the rising edge of FV was not wide enough.Now my UVC can output 30fps,thanks.
