I have to transfer data from FX3 to FPGA using GPIF II interface.I'm using the firmware that is in AN65974 and i will give data through control center.But i'm able to receive only starting 2 bytes,the remaining bytes are missing,as shown in below snapshot.What may be the reason for this,kindly anyone let me know the issue.
Aswini
Hello Aswini,
I tried to reproduce at my end.
I programmed the FX3 with default firmware and checked the flags before and after transfer (without reading it on GPIF side)
These are the traces i got with proper PCLK - initially low and gets high when some data is transferred. Flags C goes low again when DMA buffer is FULL
I also observed that if PCLK is not given properly these flags misbehave. Trace with flags without proper PCLK and before data transfer .
Initially before transfer both flags will be low as mentioned in state machine. So before transferring you should get both flags low.
Rashi
Rashi
Hello Aswini,
Rashi
Rashi
Based on your traces i'm thinking that the problem is with PCLK(FPGA side).So,can you send me the snapshot of your FPGA block design,so that i will compare it with my FPGA design(mainly clock connection).
And also please send me the FPGA files which you are using now.
Aswini
Hi Aswini,
I didn't check this with FPGA but with another CYUSB3KIT-003 (Master) .
I tested this with two CYUSB3KIT-003, one as Master (drives PCLK) and other as Slave and checked the flags status. I have just connected GPIO 16 i.e. PCLK of both kits using jumper wires
Rashi
Rashi
