brsmc_4044241
I am working on a simple design that exposes the registers of an APB mapped peripheral located in a companion FPGA to FX3.  My first instinct was to reconfigure the GPIF interface to generate native APB master to the FPGA.  It seems like this would be a fairly common application, since many peripherals are available as AMBA compliant IPs.  However, I can't seem to find any information or reference designs that do something similar.  Is this problem already solved, or do I need to create some custom glue logic to connect the GPIF to an APB bus?
abhinavg_21
Currently we don't have any example for interfacing GPIF with APB peripheral device but you can implement APB protocols on GPIF SM.
Thanks & Regards
Abhinav Garg
abhinavg_21
Thanks & Regards
Abhinav Garg
