gean_3054931
hello,
   As discussed in the previous post(FX3 SPI COMPATIBILITY ),those are supports 1.8v and 3.0v.
Is any spi flash that supports 3.3V Poer supply?
regards,
geetha.
W25X40CLSNIG spi flash support 3.3v power supply and compatible to Fx3.
Anil Srinivas.
alamandaa_16
10 likes received First like received
Hi Geetha,
MX25R8035F spi flash support 3.3v power supply.
Anil Srinivas.
  Hello Anil,
thanks for the replay.
it should satisfy the commands and compatibility with fx3s(cyusb3035)?
how can i check commands compatibility with the spi flash?
reagrds,
geetha.
Please go through the below link which speaks about the SPI Flash compatibility and the command set:
Selection of SPI Flash Compatible with FX3/CX3/FX3S/FX2G2/SD3/SD2 and the Recommended Cypress SPI Fl...
Anil Srinivas.
Hello anil srinivas,
MX25R8035F spi flash (3.3v power supply).This device is not available.
can you tell me other spi part number that are compatible to fx3?
currently which spi part number is used in FX3 dvk?
regards,
geetha.
Anil Srinivas.
