is there any available information available i.e. schematics or programming guides for using a Lupa300 and the FX3?
On semi has only limited information available.
Thanks for any help.
Please refer to the following appnote: https://www.cypress.com/documentation/application-notes/an75779-how-implement-image-sensor-interface...
You will have to modify the sensor.c file in the AN75779.zip folder to the sensor setting of lupa300 to be able to configure it and stream video using the sensor.
You can go through the appnote to get an understanding about the process of programming the image sensor.
Yashwant
