Panneerraja
Hi All,
I am using a custom board where Fx3 USB controller is connected to Xilinx FPGA.
I am trying to create an board level Vhdl/Verilog test bench where Fpga is instantiated as DUT component and
FX3 as a test peripheral component.
Is there any VHDL/Verilog simulation model available for Fx3 USB Controller?
Thanks in advance,
Panneer Raja Vajravelu.
Biren_R
First like given 250 sign-ins 50 solutions authored
Hello Panneer,
Can please provide what you wanted to test specifically using the Device Under Test?
we don't have any VHDL/Verilog simulation model to test FX3, but I like to share with you one thing if you just wanted to simulate GPIF slave FIFO only then you can use AN65974 FW and FPGA code.
Biren
Biren_R
Hello Panneer,
Biren
Hello Biren,
Thanks for the reply. Below diagram describes briefly how my board-level Testbench looks like,
[cid:image002.png@01D86C54.41685980]
Our fpga design(DUT) transfers ADC data at high-speed via FX3 to the PC.
Test stimuli is as follows,
1. Read/Write FPGA registers.
2. Stream in and out.
FX3 Simulation model is missing in my test bench. From your answer, Infineon does not have such a VHDL/Verilog simulation model.
>From what I could see, AN65974<> shows few Fx3Firmware.img executable file that is used in the Board testing. But it does not include any Fx3 VHDL/Verilog simulation model, is it not?
Panneer-Raja.
Biren_R
Hello Panneer,
Can you please send an again image I can't see any attachment?
AN65974 is include FX3 code and supported FPGA code not include any simulation model.
Biren
