I'm using the instruction from this link
I've build and upload to I2C EEPROM this image from:
"C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\boot_fw\src"
As the instruction suggest in
"b. Using Second Stage Bootloader"
When I disconnect the J4 PMODE Jumper and reset the FX3
The FX3 is Booting in Bootloader mode as I want it
But when I try to download new image to the "RAM" without the J4 PMODE Jumper
The FX3 stays in the Bootloader Mode instead of ReNumeration to the new Image that was downloaded
Do I need to add something to the code in the usb_boot.c file that is in the src File? For the FX3 to ReNumeration after downloading an image.
EliW.
USB Superspeed Peripherals
No, it was only resolved after id did this action,
The noReEnum parameter of the function CyFx3BootUsbStart () is to be set to CyFalse if the no
re-enumeration feature is to be disabled.
On another topic, does the FX3 (CYUSB3KIT-003) Support USB Low Speed Mode 1.5 megabits per second (Mbps)?
Sorry I'm not working with the folder src,
I'm working with the example from this folder
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\Workspace\Fx3BootAppGcc
Hello EliW,
Is your Issue resolved after using the correct path?
Biren
Hello EliW,
Yes, FX3 will support Low-speed mode.
Biren
