I use CYUSB3014. I am studying how to write firmware corresponding to UVC.
I want to ask that should I use the pin number (LV, FV) just like UVC_AN75779 example project? I found this discuss, AN75779 modification - FX3 with specific image sensor . I think maybe I can change it depending on my hardware. But when I set GPIO28 as dma ready flag, it is not work. The flag always be high. But other GPIO pin works fine(ex: GPIO23). I am wondering is it the restrict about UVC based firmware? Because when I set GPIO28 as dma ready flag in not UVC based firmware, it works fine. I don't know why?
Any response would be greatly appreciated.
Yes, we can change LV and FV from the GPIF tool, Default UVC project is not used DMA ready, can you please share your GPIF state machine if you are not using the default project?
what is the purpose of using DMA Ready?
Biren
Hello Biren,
Thank you for your reply.
I am not using the default UVC project. I want to receive video, audio and other data from FPGA. FPGA will check if DMA Ready before it send each data to FX3. The sw1 and sw2 signal in the state machine is to distinguish the type of data. The dma buffer of video is set as CY_U3P_DMA_TYPE_AUTO.
Sylvia
Hello Sylvia,
Thanks for sharing this info, DMA ready pin should go low when DMA is full, to understand your configuration is it possible to attach this project here.
Biren
Hi Biren,
Thank you! I am still keep debugging. I think I am not understand enough about DMA buffer.
There is GPIO pin introduce table in the official document. But I am not sure what kind of pin can be a DMA ready pin? For example, GPIO[17]~GPIO[29] (CTL[0]~CTL[12]), are all these pins can be used?
Excuse me, I got one more question when debugging. When I use a UVC application(ex: VLC, VirtualDub), when will it read the DMA buffer from U-Port? Just the time the DMA buffer write to full?
Sylvia
Thank you for your reply!
Sylvia
