StFa_289656
I made a composite USB device: UVC + HID.
framework 1.3.4
The uvc is based on AN75779.
the USB communication stop working after few seconds using USB 2.0 (USB 3.0 is ok).
I faced a similar problem with UVC when I asked extended properties very often.
Has Anyone a similar probelm?
- Please confirm that you made appropriate changes in the HIGH speed and full speed descriptors for adding  HID and extension unit.
- Are you getting any debug prints when the streaming is stopped. It seems that  Host is slow enough to issue IN tokens ( can be  the reason for overflow.
Please refer this KBAInvalid Sequence Error in Multi-Channel Commit Buffer - KBA218830  and try the changes recommended.
If this doesn't help, please probe the USB lines and share the traces. You can use Wireshark for that.
Rashi
Rashi
Rashi_Vatsa
USB 2.0 practically supports the bandwidth of 20-25 MBps. Please confirm the video stream bandwidth is <= 25MBps
What are the errors you are getting while streaming in USB 2.0
>> Does this happen in USB 2.0 or USB 3.0? What are the errors?
Rashi
Rashi
the video stream is about 25Mbps.
without communication with the HID or the extended properties the video works fine.
the error is alwasys the same: the USB staks stop to transmit data.
I have a dedicated task used to perform some operation and this task is still working.
removing the usb cable and attach it again resolve the problem (this is not acceptable).
I think there is something in the FX3 libs that don't take care to an overflow situation.
Rashi
Rashi
Yes I made a combi peripheral. I dont use and don't initialize the Full speed descriptor.
I don't have the UART available, so no debug print
I'm going to test the KBA you suggest me, I'll keep you informed
Can you debug on your side that where is the firmware failing? Please check with that CyU3PDmaMultiChannelCommitBuffer API is passing or failing.
If it is passing probe the USB lines and share the traces.
Please let me know the results for changes in KBA.
Rashi
Rashi
