gean_3054931
what is the difference between #define CY_U3P_USB_GS_INTERFACE (0x81) /(The standard device request, GET_STATUS interface  ) and #define CY_U3P_USB_GS_ENDPOINT (0x82) (The standard device request, GET_STATUS endpoint  ).
The endpoint 0X81 is used in fx3 slavefifo example as consumer endpoint.please let me know.
thank you.
abhinavg_21
CY_U3P_USB_GS_INTERFACE & CY_U3P_USB_GS_ENDPOINT are USB standard requests about the Interface and Endpoint respectively (Refer to the USB 2.0 Spec). So here 0x81 and 0x82 are bmrequest. But endpoint 0X81 used in fx3 slavefifo FW example is the EP number over which communication happen. So don't confuse CY_U3P_USB_GS_INTERFACE with endpoint 0X81 used in slavefifo example.
Thanks & Regards
Abhinav
abhinavg_21
Thanks & Regards
Abhinav
