Hello all,
I need to start a slave device which has SPI control lines interfacing with FX3 (CYUSB3KIT-003) with separate data lines (D0...D8) something. I am using SDK1.3. Is there any example which refers to the SPI control only operation with FX3?
Which mode is better to go with FW control or GPIO?
Please suggest~
/Ash
Hello Ash,
You can follow C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\GettingStartedWithFX3SDK.pdf document section 4.2.8.3 (Page 35).
I suggest you start with basic UsbSpiRegMode to test your sense interface and then you can go for UsbSpiDmaMode.
Biren
Hello Ash,
Can you please explain the question in more detail?
Biren
@Biren_R Hello Biren,
I need to interface a sensor/device which has SPI controls on it. I want to interface this with FX3. From where should I start (any SDK example), which I can update/modify accordingly to get it working....
I checked and found that in SDK there are 3 SPI examples based on modes (gpio, dma, reg), but I didn't understand with which I need to start, so I am looking for suggestions and guidance.
Hello Ash,
Biren
