jowac_1171871
5 questions asked 5 sign-ins First reply posted
I have been using an old version of FX3 SDK 1.3 since v1.3.4 have some bugs.
After searching in this forum, I found that FX3 SDK 1.3.5 was planned to be released in Dec 2019, but almost 3 years later it seems like it is still not released.
So, are there any updated release schedule?
My main issue with 1.3.4 is described here:
Solved: break does not work after upgrading to FX3 SDK 1.3... - Infineon Developer Community
Apparently, I did not try the suggested method, probably because it is not very well described how to do it.
I have seen other bugs in v1.3.4 in this forum that would need a fix.
Ajeethkumar
Moderator 50 solutions authored 10 likes received 10 likes given
FX3 SDK is undergoing validation on Linux and macOS platforms. We expect to release the SDK by Q123.
Can you list the issues you are seeing in SDK 1.3.4 here?
Ajeeth
Ajeethkumar
Ajeeth
jowac_1171871
Unfortunately, I do not have so much experience with 1.3.4, since I can't use the debugger. But I could find several reports in the forum while searching for a solution.
Will the debugger issue that I linked to be fixed in 1.3.5?
Is there an updated pre-release that we could try?
(I'm trying to solve an USB super speed issue and would make sure to have as many known issues in the SDK as possible solved)
Ajeethkumar
You can use the library attached here. This is the latest version which is Undergoing Validation.
Ajeeth
JBC
First solution authored First reply posted First question asked
'Error in CyU3PDmaMultiChannelCommitBuffer: code 71'
After searching for the above error, the following article says that it does not occur in FX3 SDK version 1.3.5 or higher, but the current version is 1.3.4.
https://community.infineon.com/t5/Knowledge-Base-Articles/FX3-Error-in-CyU3PDmaMultiChannelCommitBuf...
Ajeethkumar
Yes,  FX3 SDK 1.3.5 will come with this fix. Till then, you can use the fix mentioned in the above KBA.
Ajeeth
