I am using JLINK BASE with cypress EZ USB sdk .I am getting ERROR: Bad JTAG communication: Write to IR: Expected 0x1, got 0x7 (TAP Command : 15) @ Off 0x1157.
why this eeror ?I am not able to do debug the program.
for some application,it will not thrown ERROR: Bad JTAG communication: Write to IR: Expected 0x1, got 0x7 (TAP Command : 15) @ Off 0x1157.
but it will show starting target cpu..(as shown in the attached snap).after this,there is further debug(there is no further stepover option).help me.
thank you.
Please set the following breakpoints in the firmware and do stepover at KernelEntry
By default the debugger stops at Main.
1. Put a break point at application define function (CyFxApplicationDefine)
2. Otherone at Thread_Entry function (for example - UVCAppThread_Entry in UVC An75779 firmware )
After this, if you do stepover at kernelentry, it will take you to Application Define. Then it will take you to Thread_Entry.
Hope this solves your problem.
I have tested at my end. It is working fine.
