vaogc_284256
In new revision *W of document "CYUSB301X/CYUSB201X, EZ-USB® FX3: SuperSpeed USB Controller"
pin D11 or GPIO[60], which was an output is now labled as NC pin without any explanations.
I successfully used this pin as output earlier. Why is it NC now? Can I continue to use in with new revisions of fx3 chip silicon?
Hi Vaagn,
It doesn't matter for you. You could continue to use it as GPIO.
YangyangC_06
Hi Vaagn,
Could you please explain your application in detail? Are you using ACA based charger detection or the standard battery charger detection?
Hi yyca,
I don't use or ever need charger detection logic. But I use this pin as general purpose output by CyU3PGpioSetValue(...)
Hi Vaagn,
