charlie
5 sign-ins First solution authored First reply posted
Could you confirm if AT24CM02 256KB EEPROM can be used for FX3 I2C boot?
Did Cypress do any testing with any 256K Atmel memories?
Thanks you!
JayakrishnaT_76
Moderator First question asked 1000 replies posted 750 replies posted
Please refer to the I2C EEPROM boot section of the following Application Note:
https://www.infineon.com/dgdl/Infineon-AN76405_-EZ-USB_FX3_FX3S_boot_options-ApplicationNotes-v12_00....
If the EEPROM is compliant to the features mentioned in the Application note, then it can be used for FX3 I2C boot.
Jayakrishna
