BuYa_3858256
FX3 I2C interface in Superspeed Explorer Kit have no signals on the dev kit pins. I am using the reference design called "UsbI2cDmaMode"
I am trying to monitor i2c signals with logic analyzer and I2C protocol analyzer. BUT, i don't see any signal activity on SDA and SCLI2C_BATTERY_MANAGEMENT.png PINS on the superspeed explorer kit pin 58 and pin 59 pins. SCL_SDA_VBUS_GND.png
Please use the Cypress USB Control Center application to issue the vendor commands. You can refer to the CyControlCenter.pdf document (see attachment) for guidance on usage of the tool.
Srinath S
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
- Have you issued the vendor commands from the host application and have they been successful?
- If yes, please send the captures from the I2C lines.
Srinath S
Could you elaborate the vendor commands and how to enter from the host application?
Srinath S
