KeWa_2323766
Level 4
Level 4
First solution authored 25 replies posted 10 replies posted
FX3 GPIO46 is used as PWM output.  I refer to excel document attached to the thread
https://community.cypress.com/t5/USB-Superspeed-Peripherals/IO-Drive-Strength-configuration-for-P-po...
But in this document, with same IO VDD, IOH, Drive strength, different Forced VDD will result in different drive current for GPIO46.
1.  What does " forced VDD" mean in the excel file?
2.  What is default GPIO drive strength when no CyU3PSetGpioDriveStrength( ) called to set drive strength, 1/4,2/4,3/4 or 1?
3. Is there difference between simple GPIO and complex GPIO in term of drive strength?
Thank you.
Kelly
Hello Kelly,
Apologies for the confusion
Please check the table 9  in the latest FX3 datasheet https://www.cypress.com/file/140296/download
As per the FX3 TRM, the default drive strength will be Half strength as the default value of GCTL_DS register  is 2
 0 Quarter strength
1 Three quarter strength
2 Half strength
3 Full strength
Rashi
Rashi_Vatsa
Hello Kelly,
Please find my comment below
You can refer to table 9 of the FX3 datasheet for the current values for different drive levels
>> Please refer to section 10.4.4 of  FX3 TRM. It mentions about the GCTL_DS register. You can also refer to this thread Solved: what is the default state of CyU3PDriveStrengthSta... - Cypress Developer Community
I will  get back to you after confirming for the other questions
Rashi
Rashi,
I am not able to find GPIO current values in data sheet Table 9 . Table 9 is for GPIF ii timing.  Please see the screen shot below.
If you help me  explain the forced VDD, it would help me a lot .
Kelly
Rashi_Vatsa
The drive strength of all the GPIO by default will be Three-Quarters
Rashi
Hello Kelly,
 0 Quarter strength
2 Half strength
3 Full strength
Rashi
