Hi infineon team,
I tried to use GPIO[32]/PMODE[2] pin as simple GPIO after the boot sequence in FX3 . but i am getting setsimpleconfig failed error code=0x44. I searched in the community by using below link and found that this issue is solved by some patch file. kindly provide us the same patch file.
community link:GPIO[32:30]: After boot-up, these signals can be u... - Infineon Developer Community
Note : Im using 1.3.1 SDK for this project. but in 1.3.4 also we are facing this issue.provide patch file for 1.3.1 SDK.
Thanks and regards,
Rakesh
Hello Rakesh,
Did you override the pin just before you use it? Use CyU3PDeviceGpioOverride(32, CyTrue) for pin GPIO 32.
Sakshi Bakal
Hi Sakshi,
Yes i have done override before using it.
kindly provide us the patch which is mentioned in the thread GPIO[32:30]: After boot-up, these signals can be u... - Infineon Developer Community
Thanks and regards,
Rakesh
Hi sakshi,
kindly give us a update on above issue .
Thanks and regards,
Rakesh
Hello Rakesh,
Please uninstall the old SDK version, install the latest version (1.3.4), and try again.
Sakshi Bakal
Hi sakshi,
we have issues in 1.3.4 SDK and we got patch from your team and mentioned it will be rectified in 1.3.5 SDK . so we are unable to use 1.3.4 SDK in our project. so please give us patch file mentioned in the below link for 1.3.1 SDK.
Note :FYI, Regarding 1.3.4 issue we have discussed in the below thread and got patch from your team.
Apart from this issue we are waiting for 1.3.5 SDK release . please update us the release date for 1.3.5 SDK.
Thanks and regards,
Rakesh
