I am using the FX3 Explorer Kit and an OV5640 sensor, I would like to capture JPEG pictures but need to configure GPIFII for that purpose since VSYNC is not available in that format only HREF. Do you have a GPIFII designer example file that does that?
Thanks a lot
USB Superspeed Peripherals
By capture JPEG pictures, you mean to do still image capture for the MJPEG videos. Is my understanding correct?
We have AN75779 firmware example project, you could try modifying for your application. We would be happy to answer your queries.
You can get the project from the below link:
https://www.cypress.com/documentation/application-notes/an75779-how-implement-image-sensor-interface...
AliAsgar.
AliAsgar.
