GPIF II - FPGA interface
GPIF is sychronous master 8bit multiplexed address data
Address is 24 bit, data is 32 bit
Clock can go in either direction
Output 3 controls signals to FPGA
ALE - address latch enable, asserted low
DEN - data enable for reads and writes, asserted low
LWR - local write, high for writes, low for reads
ALE, A[23:16]
ALE, A[15: 8]
ALE, A[ 7: 0]
WAIT - if read operation LWR = 0
DEN, D[31:24]
DEN, D[23:16]
DEN, D[15: 8]
DEN, D[ 7: 0]
Repeat data transactions if burst, address auto increments
Address pins bus width can range from 0 to 8. Not more than that. So having a 24 bit wide address bus is not possible.
You can have 32 Bit data bus multiplexed with 8 bit address bus.
- Madhu Sudhan
- Madhu Sudhan
