Hello
Please tell me about the pin status of G7 (FLAGA).
Target parts: CYUSB3014-BZXI (FX3)
FX3 mode: SlaveFIFO
Target pin: G7 (FLAGA)
Phenomenon: After the power is turned on, the G7 output is undefined when the USB is not connected.
Assumption: Only the power is applied to the FX3 implementing board without connecting the USB cable.
Q1) Please tell me the output specifications of FLAGA after the power is turned on and there is no USB connection.
Q2) After turning on the power, can the output of FLAGA become indefinite (Hi-z, etc)?
If so, what are the possible causes?
Q3) As a workaround for "Q2" above, is it possible to improvement the FLAGA output from becoming indefinite by changing the firmware of FX3 without changing the H/W?
Arai
USB Superspeed Peripherals
Hi Arai-san,
"After the power is turned on, the G7 output is undefined when the USB is not connected."
>> Could you let me know what you meant by G7 output is undefined? Is it tri-stated? Could you describe undefined a bit more?
What is the boot option for the FX3? Kindly refer to the application note for default states of IOs during different boot options : https://www.infineon.com/dgdl/Infineon-AN76405_-EZ-USB_FX3_FX3S_boot_options-ApplicationNotes-v12_00....
"As a workaround for "Q2" above, is it possible to improvement the FLAGA output from becoming indefinite by changing the firmware of FX3 without changing the H/W?"
>> From this line I understand that you want to configure FLAGA to be tri-stated in the firmware. Is my understanding correct. If yes, make the driveLowEn and driveHighEn to CyFalse during GPIO configuration.
Could you explain a bit more about the application of this?
AliAsgar
Hi Arai-san,
AliAsgar
