Hi!
I just installed EZ-USB suite to start programming CYUSB3033 and now I am trying to compile example (GpifToUsb).
I cannot get rid of this error:
/usr/lib/gcc/arm-none-eabi/4.9.3/../../../arm-none-eabi/bin/ld: GpifToUsb.elf: warning: sh_link not set for section `.ARM.exidx'
I tried .ld files for 256kB and 512kB of ram but still no success.. Can anyone help?
Is it maybe connected to the error after this :
Cannot run program "/util/elf2img/elf2img" (in directory "/home/orion/workspace_easy/GpifToUsb/Debug"): error=2, No such file or directory
Error: Program "/util/elf2img/elf2img" not found in PATH
PATH=[/usr/bin]
Thnaks for the answers!
Edit:
I solved the problem by commenting out the last ". = ALIGN(4);" statement(in the .ARM.exidx section) in the fx3.ld file.
