According to table 31 in AN76405 "EZ-USB® FX3™/FX3S™ Boot Options" the state of GPIO[17] a.k.a. CTL[0] is "Tristate"
"while the bootloader is executing".
I have some questions related to that table.
Questions:
1) What is meant exactly by "while the bootloader is executing"? Does this table apply when you just plug the EZ-USB board into USB, before loading any firmware, so when the device enumerates as "Cypress FX3 USB Bootloader Device"?
2) The document AN76405 states that the state of GPIO[17] a.k.a. CTL[0] is "Tristate". However, in the situation described under 1) I measure that GPIO[17] is HIGH (in my case 3.3V). Is this correct? My PMODE pins [2,1,0] are low,high,high (USB boot).
The question is relevant, because I use GPIO[17] as RESETN pin for an image sensor. When I first plug in the EZ-USB board into USB, I want GPIO[17] to be LOW to keep the image sensor in reset, before I load the actual firmware over USB. I tried a weak external pull down on GPIO[17] but that did not work, so it is definitely not in a TRISTATE condition as AN76405 suggests...
USB Superspeed Peripherals
Please let me know the status of J5 jumper status of CTL0 pin is checked. The J5 jumper on CYUSB3KIT-003 is expected to be removed when SRAM interface is not enabled.
This is because, if J5 jumper is not removed, CTL0 pin will be pulled up ( Please refer to Superspeed explorer kit schematics )
Rashi
Please find my comments below
>> Yes, "while the bootloader is executing" means before the application firmware is programmed to FX3 and the bootloader is running on FX3.
>> For USB Boot, the PMODE[2:0] should be Z11. Also, let me know how did you measure voltage on GPIO? Please let me know the value resistor used to pull down the GPIO
Rashi
Regarding PMODE[2:0] : the only thing I do to enforce USB boot is to apply PMODE jumper J4 on the EZ-USB board. The resulting PMODE pins [2,1,0] are low,high,high (0,3.3V 3.3V) is what I subsequently measure at these pins with a digital volt meter. I can succesfully boot over USB. In fact I can get live camera images, all works. I just want to get a "neat" and "clean" boot behaviour on GPIO[17]. By the way I run the EZ-USB board with 3.3V GPIOs (with that dedicated jumper in place).
I tried 2 different pull down resistors on GPIO[17]:
47kohm and 10kOhm. Both were not low enough to get a "safe" logical zero on GPIO[17] during boot load.
Rashi
Hi Rashi,
Indeed, I have jumper jumper J5 in place, because I use the SRAM.
So that explains why CTL0 is high when I first power the board.
So I will use CTL1 then as RESETN signal for the sensor.
Can you please confirm that CTL1 is low when jumpers J2,3,4,5 are all present when I first power up the board?
Does it require an external pull down resistor on the sensor board to guarantee that CTL1 is low at first power up?
Once you confirm, I will rework the sensor PCB design..
Sander
You can refer to SuperSpeed explorer kit schematics (attached) , CTL1 ( GPIO[18]) is not pulled up to 3.3V as done for CTL0 (when J5 is populated)
As per AN76405, the default state of FX3 GPIO[18] while the bootloader is executing before
application firmware download, is Tristate (USB Boot). So, a pull down resistor (10k ohm) will be required to pull down CLT1.
Rashi
