Which version of the SDK are you using?
If you're not using Beta-2 can you please migrate to it and see if you're observing the same?
Anand
We're able to replicate this at our end. We're currently investigating this, I'll update you once this is fixed.
Anand
It seems a single buffer cannot be used to hold multiple packets of data when the max. packet size is odd. It will be necessary to package the data with only packet per buffer. If multiple packets need to be sent, different CyU3PDmaChannelSetupSendBuffer calls need to be made. A better method would be to get the pre-allocated buffers for the channel using CyU3PDmaChannelGetBuffer, put the data in this buffer and then commit using CyU3PDmaChannelCommitBuffer. Please check if this resolves the issue.
Anand
