Cy3014 connected with Android Phone, Do have the driver run on the android phone?
We do not provide any android specific drivers. You can use the Linux libraries and wrapper which is present in the FX3_SDK_Linux. The device will be supported by through libusb
Can these Linux Libraries also run on ARM?
Fx3 operation in Linux relies on the Libusb. If the LibUSB does not cause any problem with ARM, then you will be able to use FX3
