I want to pass the FX3 Compliance Test. There is a statement in the KBA at the URL below that "cyfxbulksrcsink" should be used, so I am trying to use it.
https://community.infineon.com/t5/Knowledge-Base-Articles/FX3-FAQs-KBA224051/ta-p/257566
I want to enter Loopback Mode by checking the Jitter Tolerance of RX. What should I do? Do you have a sample FW?
Tetsuo
Hello Tetsuo-san,
Please refer to this KBA for Compliance tests Procedure for USB 3.1 Tx and Rx Compliance tests f... - Infineon Developer Community
You can also use the Bulk Loop example for SDK Release 1.3.4 can be used for the Jitter Tolerance of RX test.
Rashi
Hello Tetsuo-san,
Rashi
