FX3
I have a complex GPIO set as a 1HZ timer with interrupt. I get the interrupt until I start sending messages.
Below is the GIO configuration.
/* Configure GPIO 33 as 1PPS input */
ppsGpioConfigComplex.outValue = CyFalse;
ppsGpioConfigComplex.inputEn = CyFalse;
ppsGpioConfigComplex.driveLowEn = CyFalse;
ppsGpioConfigComplex.driveHighEn = CyFalse;
ppsGpioConfigComplex.intrMode = CY_U3P_GPIO_INTR_TIMER_THRES;
ppsGpioConfigComplex.period = 192000000;
ppsGpioConfigComplex.pinMode = CY_U3P_GPIO_MODE_STATIC;
ppsGpioConfigComplex.threshold = 192000000;
ppsGpioConfigComplex.timer = 0; // Timer initial value
ppsGpioConfigComplex.timerMode = CY_U3P_GPIO_TIMER_HIGH_FREQ;
apiRetStatus = CyU3PGpioSetComplexConfig(PPS_MONITOR, &ppsGpioConfigComplex);
Found Workaround.
If I change CY_U3P_GPIO_INTR_TIMER_THRES to CY_U3P_GPIO_INTR_TIMER_ZERO I get the interrupts after I start my messages.
This does not answer why CY_U3P_GPIO_INTR_TIMER_THRES does not work after starting my message transfers.
