I have merged the bulkloop and the i2c exemple together. When i EEPROM_WRITE i made those line of code so i can see what is being transfered to i2c which works fine.
status = CyU3PUsbGetEP0Data(wLength, glEp0Buffer, NULL);
taille=sizeof(glEp0Buffer);
for(i=0;i<taille;i++) CyU3PDebugPrint (1, "%x",*(glEp0Buffer+i));
I made 7 endpoint (1 EP0 for I2C and 6 for bulkloop kind of tranfer) Now i want to see what is tranferred in the endpoint BULKLOOP by the debug interface. I conected 2 endpoints to 1 DMA socket 3 times. (i need all those EPs my API need it)
My goal here is to
-receive a structure of data from one endpoint which will be sent from the host.
-Do what the data has to do (read eeprom, write eeprom, i2c communication, ect..)
-send informetion to the host
My biggest concern is that i cant see what is in those endpoints can anyone tell me the function to acces this memory.
HI,
You can make the DMA Channels associated with the BullkLoop EndPoints as Manual. In a Manual Channel, you can actually print the data being transferred inside the call back function. Please refer USBBulklLoopManual example firmware.
- Madhu Sudhan
