EZ-usb-suite complie error
hello,everyone,
what does this mean? I copy the program from forum.thank you ! I put it in the attaches,because paste always error!
Could you tell the forum post which you are referring to?
If you are getting build errors, try the following:
Right-click on the project and select Index->Freshen All Files. Then, select Index->Rebuild. After this, build the project.
        sorry,I have solved !thank you!
