user_4012861
I am just starting to play around with CY7C68013A. I have a very simple board and I am trying to build Bulkloop_SDCC template project. I am very confused when I try to build this project. I get many errors when I open any of the .c file in the projects (as long as I don't take a look at the code not error shows up). When I try to build it, it builds it very quickly.
here is the console: (the project name is "projectName")
16:05:23 **** Incremental Build of configuration Release for project projectName ****
make -k
Building file: ../EZRegs.c
Invoking: SDCC Compiler
make: Interrupt/Exception caught (code = 0xc00000fd, addr = 0x4227d3)
16:05:24 Build Finished (took 189ms)
I don't really know what's going on. I am very new to this subject. Can you advice?
YiZ_31
FX2LP projects do not use EZ USB suite. You should use keil uvision2 to build project for FX2LP.
You can download keil IDE form this page:
https://www.cypress.com/documentation/development-kitsboards/cy3684-ez-usb-fx2lp-development-kit
Eddie
YiZ_31
Eddie
Firts of all. Thanks for your response.
I know keil has some limitation in terms of program size and I don't want to pay for the full version of Keil because it's very expensive. What are the other options for developing software for this controller?
YiZ_31
Keil is the official programming tool for FX2LP, we do not supply other options. I'm afraid I can not give you suggestion on this.
Eddie
Is there any other processor that supports hi-speed USB interface and other development environment that doesn'T have any limitations?
YiZ_31
We have FX3 supports Super-speed USB interface, EZ USB Suite is designed for it. We do not have similar device only for USB 2.0 except of FX2. Thank you for understanding.
Eddie
