Dear community,
I encounter an issue with IO matrix initialization in the BulkLpAutoCpp example.
When I set the field useSpi to CyTrue, it never goes to CyFxApplicationDefine and the threads aren't launched.
It's working with other example but not this one.
I'd like to use both I2C & SPI. I'd like to use the Uart for debugging purpose.
Thank you for your help.
USB Superspeed Peripherals
Please change the lppmode in the IO configuration to "CY_U3P_IO_MATRIX_LPP_DEFAULT"This mode enables all LPP.
"CY_U3P_IO_MATRIX_LPP_UART_ONLY", this enables GPIF-16 bit and UART only.
AliAsgar
Here is the top part of the main function
AliAsgar
