How do I purchase the Aptina sensor board to work with EZ-USB® FX3™ SuperSpeed Explorer Kit and Aptina™ Image Sensor Interconnect Board for the EZ-USB® FX3™ SuperSpeed Explorer Kit ?
This image board is not available from Cypress store. Please contact to OnSemi conductor to find the channel.
Any board which has same hardware interface and same signal specification would be OK.
Can you recommend me on a Board that it will be easy to buy ?
I am not aware of the product lines of On Semi. You could contact OnSemi first and get the information of latest camera boards.
Then I could check for you to see if they are compatiable.
