I've been using the BulkLoop.exe that comes with the EZ-USB-FX-SDK to verify the hardware on a custom board with a CYUSB3014-BZXI device on it.
After searching around, the only technical documentation I found on it was a short Knowledge Base Article by Cypress.
I was wondering if there was any other documentation out there, or if anybody else has used the tool.
A few details I'd like to know about the tool are:
- What's the transfer speed of the tool? (From using the tool, it seems to be about 0.0417 MB/sec, which seems a bit slow)
- What's the data that's being transferred? Is it a single byte? For incrementing, when it reaches 0xFF, does it overflow to 0x00 and restart?
Thanks!
Actually found the answer to my question. The cpp project can be found for bulkLoop.exe at <where SDK is installed>\.3\application\cpp\bulkloop\x86
