gean_3054931
I am merging slavefifo interface and gpiftostoarge fx3 firmware examples,
i am getting following errors,please find below and also attached firmware.
help me.
thank you
Please check the attachment. You didn't make the correct configuration.
HeLi_263931
Level 8
Level 8
"Undefined reference" means that you either forgot to add a needed source file, or did not specifiy a library that needs to be added to the linker. Probably its the latter. Since you did cut off the actual error message its hard to tell you more.
I have attached the error message,its showing error for cypress API,help meer.bmp
Thank you so much,
what was my mistake?
You don't add the library path in the settings.  You could check the project enclosed to know the detailed information.
thank you,
how to add library path?
For any project, righe click and choose "properity". You could import any example project into workspace to study how to set it.
hello,
did you add cyu3sport library to my firmare?
i am asking how to add this library(cyu3sport)?how to select directory path?
let me know
