If not, is there a plan to add the support to it? Is there an experimental driver that I can test with?
The CyUSB3 driver does not support USB3.0 bulk streams. Kindly refer to this for more details: https://community.infineon.com/t5/USB-superspeed-peripherals/Why-do-these-known-issues-still-exist-C...
Meghavi
Can you please confirm whether you are referring to streaming through multiple endpoints or USB3.0 bulk streaming interface?
Meghavi
Hello Meghavi,
Thanks. I mean USB 3.0 multiple streams to the same endpoint. https://docs.microsoft.com/en-us/windows-hardware/drivers/usbcon/how-to-open-streams-in-a-usb-endpoi...
Meghavi
Hi Meghavi, thanks for the reply..
