HamburgSteak
10 replies posted 25 sign-ins 10 sign-ins
Hi, I have a question with CX3.
Does SPI support 3-wire communication in CX3?
Biren
First like given 250 sign-ins 50 solutions authored
CX3 does not support 3 wire SPI (SCK, SS, SDIO).
You can still try some workaround, please check below link code side you may need to follow SPI registers. this is not tested this is one idea it may be work or not.
https://arduino.stackexchange.com/questions/66076/read-write-with-half-duplex-spi
Biren
Biren
- Can explain more about the use case?
- Are you looking for SPI as master or slave?
- Are you looking for 3 wires as SCK, MOSI, MISO only or SCK, SS, SDIO?
Biren
Hi, I described my configurations below.
    + I'm developing 3D camera and need to control VCSEL driver via SPI. The vcsel driver support 3-wire SPI communication.
     + CX3 is the master.
     + The VCSEL driver support SPI with SCK, SS, SDIO.
That's all.
Thank you.
Biren
Biren
I appreciate that you helping.
I will try to implement SPI.
Thanks  a lot.
