- Email to a Friend
Hi, I have a question with CX3.
Does SPI support 3-wire communication in CX3?
USB Superspeed Peripherals
- Email to a Friend
CX3 does not support 3 wire SPI (SCK, SS, SDIO).
You can still try some workaround, please check below link code side you may need to follow SPI registers. this is not tested this is one idea it may be work or not.
https://arduino.stackexchange.com/questions/66076/read-write-with-half-duplex-spi
Biren
- Email to a Friend
- Can explain more about the use case?
- Are you looking for SPI as master or slave?
- Are you looking for 3 wires as SCK, MOSI, MISO only or SCK, SS, SDIO?
Biren
- Email to a Friend
Hi, I described my configurations below.
+ I'm developing 3D camera and need to control VCSEL driver via SPI. The vcsel driver support 3-wire SPI communication.
+ CX3 is the master.
+ The VCSEL driver support SPI with SCK, SS, SDIO.
That's all.
Thank you.
- Email to a Friend
Biren
- Email to a Friend
I appreciate that you helping.
I will try to implement SPI.
Thanks a lot.
