Does INT# work in Slave FIFO 32-bit mode?
You can find details on this in the page 32(Pin Description section) of the FX3 data sheet.
INT# line acts as a control line when you configure the GPIF to work in Slave. It is available as INT# when you configure GPIF as master.
sai krishna.
