Are there instruction docs about how to design a carrier board for CYUSB3KIT-003 like header spec and position? Now the only reference is the gerber files of CYUSB3KIT-003.
Another problem is, the header part number ASP-181562-01 can not be found on Semtec's website.
Can you please specify what carrier board are you designing?
Which interface would be used to connect the CYUSB3Kit-003 to another board.
The header part number ASP-181562-01 was custom designed for Cypress Semiconductors.
You can go through the snapshot that i have attached and contact that company with the specifications provided to get a custom header.
Yashwant
Yashwant
