We currently use FX3 for UVC application. In road map, SX3 is highlighted for UVC while FX3 is not. May I know the difference between FX3 and SX3?
This small training PSS_eLearning_1932_EZ-USB_SuperSpeed_USB_solution_english helps you to select the product for your project and it also explains the differences between both products.
FX3 required firmware development which allows his flexibility and more control over FW in cost of development time whereas SX3 can be configured for UVC applicants just using configuration utility which reduces overall development time.
Biren
Biren
