Good day.
I'm Sophia.
My circuit board has USB PD + FX3 chip + USB Switch, and using Type C connector, how to let PC know FX3 device?
I had tried to download driver for FX3 EVM board and my PC can detect FX3 EVM Board inserted.
But my PC can't know my own design circuit board with FX3.
Pmode [2,1,0]=z,1,z .
The design is using Type C connector and USB 3.0 Switch.
The SEL pin of PI3USB302-A can work normally.
Thank you for your support and help
YiZ_31
One problem I see from this schematic is that if you want to build a PD-sink device then you should connect CC pin to gnd with 5.1k pull-down resistor.
You can refer to this KBA:
Designing FX3™/CX3-Based USB Type-C Products - KBA218460
Eddie
YiZ_31
Eddie
Dear Eddie:
CC1 CC2 are connected to USB PD pin for CC1/CC2 detection, and let PI3USB302-A to switch the USB 3.0 signal.
And the USB Switch can work normally.
Thanks for the reply.
YiZ_31
Hi Sophia,
FX3 does not have CC pin, what device is it in your last reply?
Eddie
