Debug problem for firmware of CYPD3125-40 adding TUSB1046I MUX control
ChPa_1603671
I am trying to modify the firmware of the CYPD3125-40 in Notebook mode to control our Mux from TI TUSB1046I.
I have problems debugging the firmware using the MiniProg3 and SWD jtag interface. The pins are configured correctly for SWD debug.
I am using the PSoC Creator 4.2 to build and debug the code and test it with the CY4531 development kit.
After programming the device I "Select Debug Target". Than I select "Attach to Running Target" to get in debug mode.
Most of the times i get stucked to the cy_bootloader() and dont come to the main.
Sometimes i come to the main() and can stepwise debug for some lines but than i get the message:
Error: dbg.M0015: Debugger exited unexpectedly during run.  Encountered error (Target disconnected See output window for more information.)
can someone help me debugging the CYPD3125-40 with the CY4531 devkit?
Christian
YatheeshD_36
Please use the noboot project to debug the firmware. You can refer to this thread How to debug cypd3135 in cy4531? .
Also please refer to this KBA : Debugging CCG3PA with a MiniProg3/Miniprog4 - KBA227291
Yatheesh
YatheeshD_36
Yatheesh
ChPa_1603671
that solved my problem. I was able to debug the Code after setting the #define  HPI_WATCHDOG_RESET_ENABLE to 0 and the #define SYS_DEEPSLEEP_ENABLE to 0 in the config.h file of the noboot project.
Christian
