MaSt_4567191
Level 4
Level 4
Hello
I get the following error while debugging a cx3 project based on EZUSB
ERROR: Bad JTAG communication: Write to IR: Expected 0x1, got 0x0 (TAP Command : 2) @ Off 0x5.
when
status = CyU3PSysEnterSuspendMode (CY_U3P_SYS_USB_BUS_ACTVTY_WAKEUP_SRC, 0, &wakeReason);
MaSt_4567191
Level 4
Level 4
maybe this is kinda phisiological behaviour of the program (steppin with ICE hurts the USB-related activity right?)
Thank you so much!
I think this should be documented by cypress in the JTAG ICE setup section!
Thank you for your suggestion.
We will consider to describe this information into the document as well.
Hirotaka Takayama
