ankitvats846
10 sign-ins 5 questions asked 5 sign-ins
Hi , on my device there no UART pins.
I take the reference of "cyfxusbdebug" example code to print the Debug messages on USB interface.
I configure the Endpoint as interrupt endpoint.
epCfg.enable = CyTrue;
epCfg.epType = CY_U3P_USB_EP_INTR;
epCfg.burstLen = (usbSpeed == CY_U3P_SUPER_SPEED) ? (BURST_LEN) : 1;
epCfg.streams = 0;
epCfg.pcktSize = size;
/* Interrupt  endpoint configuration */
 CyU3PSetEpConfig(CY_FX_EP_DEBUG, &epCfg);
After that I make the entry this endpoint on "cyfxusbdscr.c"   in   CyFxUSBSSConfigDscr[], CyFxUSBHSConfigDscr[],CyFxUSBFSConfigDscr[]  descriptors
And Host application retrieve the data through interrupt endpoint.
while (1)
// cout << "In Thread" << endl;
if ((lpParams->IsOpen() == TRUE) && 1)
if (lpParams->InterruptInEndPt)
length = lsize - 1;
if ((lpParams->InterruptInEndPt->XferData(fInBuf, length) == FALSE))
Sleep(100);
cout << "InterruptInEndPt->XferData Failure!" << endl;
else
cout << "RD= " << length << endl;
if (length == 0)
cout << "IN THREAD LENGTH_0" << endl;
#if 0
if ((m_bLogFileOpenFlag == TRUE))
fclose(wrLogFile);
m_bLogFileOpenFlag = FALSE;
#endif
Sleep(100);
else
cout << "IN THREAD LENGTH_NON_0" << endl;
fInBuf[length + 1] = '\0';
#if 0
if (m_bLogFileOpenFlag == FALSE)
wrLogFile = fopen(DEBUF_FILE_NAME, "a+"); //TODO FIle check
m_bLogFileOpenFlag = TRUE;
#endif
// Sleep(100);
wrLogFile = fopen("./Fwlog.txt", "a+");
fwrite((fInBuf /*+ 8*/), 1, length, wrLogFile);
fclose(wrLogFile);
else
cout << "No Interrupt Endpoint on Device" << endl;
break;
this error
 The Debug are not coming ??
Biren
Moderator 50 solutions authored 10 likes received 100 replies posted
Can you print "length" value in host app before calling "XferData", "length" must be grate then 128.
Biren
Biren
Biren
