EsPo_3827446
Level 4
Level 4
25 replies posted 25 sign-ins 10 replies posted
I want to debug the program.
Run->Debug Configuration
Error with command: gdb --version
Cannot run program "gdb": CreateProcess error=2, The system cannot find the file specified
Esakki
Please follow the suggestion mentioned in response 5 of the following thread and let me know if it helps:
Denebola CX3 board with JTAG Segger J-Link
Jayakrishna
Jayakrishna
JayakrishnaT_76
Please let me know the following details to understand the problem better:
1. Which firmware are you trying to debug? Is it an SDK example or your own custom project?
2. Are you making use of a custom board using FX3 or the Superspeed Explorer Kit or any other Reference Design Kits?
3. Please let me know if you are trying to debug with OpenOCD or using Zegger J-Link.
4. Did you go through the section 3 of EzUsbSuite_UG.pdf that comes along with FX3 SDK which describes in detail about JTAG debugging of FX3 projects? The document can be found in the following location:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\firmware
Note: The path mentioned above depends on the installation directory of FX3 SDK.
Jayakrishna
Jayakrishna
Hi Jayakrishna,
1. FX3 Superspeed Explorer Kit, both  example firmware and own custom project. Initially start with example SDK firmware -bulkloopauto.
2. FX3 Superspeed Explorer Kit.
3.  I followed EzUsbSuite_UG.pdf, I tried to debug with OpenOCD and Segger J-Link.
4. Yes, I went through the section 3 of EzUsbSuite_UG.pdf, upto step 7, I didn't get popup window, I got bellow error.
Thanks & Regards,
Esakki
Jayakrishna
Jayakrishna
