Cypress FX3 Multiple Image Files
Hi All,
Is there a way to create more than one image file under the debug folder when working on Cypress EZ USB Suite? I am currently using the FX3 Super Speed Kit and working on the SRAM_FX3 example from the SDK that I downloaded. I am using this project as a reference for my application and running multiple configurations of GPIF files, and it would be helpful if I can have an .img file for each GPIF file I modify.
I am new to this chip and any advice would be helpful.
Gil
You will have to do this manually. First build with one GPIF config, then keep the img in some other folder. Next you need to copy the other GPIF configuration and generate the next .img and so on.
