i am using the FX3 SuperSpeed Explorer Kit, Windows 7 64 bit, Matlab 2018a.
If i try to connect Matlab to the Board via the CyUSB.dll, it results in error:
System.OverflowException: Arithmetic operation resulted in an overflow.
The code i am running is simple, the second line causes the error:
cyusb_lib = NET.addAssembly('E:\Projekte\Cypress\CyUSB.dll');
devList = CyUSB.USBDeviceList(CyUSB.CyConst.DEVICES_CYUSB);
I read a lot about problems with x64 and the CyUSB.dll, but theres nothing that is working for me.
I use the latest drivers and CyUSB.dll version 3.4.7
I have to add, that the code can run without error in like 1 out of 10-15 trials, but then matlab crashes after i try to run:
myUSBDevice = devList.Item(0);
which is also a known issue to many other users.
Thank you for your help
Sebastian
Down below i post the full error-log from Microsoft .NET Framework popup (why does it only say Win32 all the time, not Win64?):
************** Exception Text **************
at CyUSB.PInvoke.CountDevices(Guid g)
at CyUSB.USBDevice.get_DeviceCount()
at CyUSB.USBDeviceList.Add()
at CyUSB.USBDeviceList.PnP_Event_Handler(IntPtr pnpEvent, IntPtr hRemovedDevice)
at CyUSB.MsgForm.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3062.0 built by: NET472REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
dotnetcli
Assembly Version: 1.0.6611.7500
Win32 Version:
CodeBase: file:///E:/Programme/Matlab2018/bin/win64/dotnetcli.DLL
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
CyUSB
Assembly Version: 3.4.7.0
Win32 Version: 3.4.7.0
CodeBase: file:///E:/Projekte/Cypress/CyUSB.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Hello Sebastian,
Please use the latest version of CyUSB.DLL from the FX3 SDK. The version number is 1.2.3.0. Kindly, test using this and let me know if the issue still persists.
Srinath S
Hello Sebastian,
Srinath S
I deinstalled everything and reinstalled, making sure to only have the latest components.
But i don't understand how i got the wrong version because i used the same installers just a couple of days ago.
Know it works, thank you for that, although i think it's strange that version 1.2.3.0 is supposed to be newer than version 3.4.7.0, maybe that's causing some confusion for other users too.
Sebastian
Hello Sebastian,
The numbering convention of 3.4.7.x was used with DLL and driver files associated with the older Cypress driver (CyUSB), which is now retired. The convention of 1.2.3.x is now being used with DLL and driver files associated with the latest Cypress driver (CyUSB3).
Srinath S
