I encountered a problem when I use the CyUSB.dll. My development tool: Visual Studio2017. I can use CyUSB.dll normally in .NET Framework4 and X64 platform of Visual Studio, but when the .NET Framework version is 4.7.1/4.7.2, the software will cause a problem. So I want to know that whether the CyUSB.dll supports the .NET Framework 4.7.1 or 4.7.2 in X64 platform of Visual Studio2017.Run error message: "System.OverflowException:"Arithmetic operation resulted in an overflow."".
USB Superspeed Peripherals
Please let me know the version of CyUSB.dll used for developing the Application. If the version is not 1.2.3.0, then please do not use that version of CyUSB.dll. Please make use of version 1.2.3.0 for developing Applications. This version of CyUSB.dll comes along with FX3 SDK. As you might be knowing, FX3 SDK can be downloaded from the following website:
https://www.cypress.com/documentation/software-and-drivers/ez-usb-fx3-software-development-kit
After downloading and installing the FX3 SDK, the DLL can be found in the following location:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\library\c_sharp\lib
Please try this and let me know the result. Also, is it possible to share the complete Visual Studio Project with us?
Jayakrishna
Jayakrishna
