When I run the USBBulkSourceSink example and try to get the FX3 to switch back to the 2 stage booter by calling the function CyU3PUsbJumpBackToBooter the function returns with CY_U3P_ERROR_OPERN_DISABLED and according to the FX3APIguide this means that the FX3 2 stage booter doesn't support switching back. Before calling this function the CyU3PUsbSetBootSwitch(CyTrue) is called.
Could anyone help me to get this to work.
Sodafarl
Hi Sodafarl,
You have to build your .img so that what gets control first is a subprogram based on the boot_fw. See here:
http://www.cypress.com/?app=forum&id=167&rID=72994
I realize that that thread isn't quite your scenario but I think the overall concept of a boot_fw subprogram and a "real" program is what you need.
Steve
Hi Steve,
Thanks for you answer and link. I 'll try this out and report back if I get anywhere. When Cypress included the CyU3PUsbJumpBackToBooter function in the USBBulkSourceSink example I thought it would be as simple as just calling this function. Other people seem to be able to get it to work :
http://www.cypress.com/?app=forum&id=167&rID=67973
It would help if Cypress could come back on this one.
Liam
