There are four CyU3PUsbEpEvtControl calls in DMA manual example "C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\dma_examples\cyfxbulklpmanual"
But there is no such call in cyfxbulklpman_removal example.
What is the purpose of CyU3PUsbEpEvtControl in cyfxbulklpmanual, when is such calls required?
It's just that the API CyU3PUsbEpEvtControl() calls are demonstrated in that example. This API is used to enable event masks for specific endpoints after ep-event callback is registered through CyU3PUsbRegisterEpEvtCallback(). In this example the API is used to disable/ re-enable the NAK event when necessary.
Hemanth
Hemanth
